No Cold Water Out Of Mixing Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2010, 09:20 AM   #1
No cold water out of mixing valve?
I recently bought a NEw home (new to me) and there were a few plumbing issues. some cut pipes and broken valves. HAd to rerout a few lines in the basement and cap a few ends. Nothing big, but I'm stumped here...
I was handy enough to sweat the pipes that needed replacment, but the shower is "stump'in" me?
At first the cold water wouldn't shut off, so I replaced the mixing valve and shower head. Now the cold water won't come out?? I have hot water, but nothing when cold is on?
Ideas?
Oh, it is a Moen Adler shower set-up. I also installed a shutoff valve before the cold intake so I know there is water coming into the valve, just not out?
thanks so much.
apex_predetor is offline   Reply With Quote
Old 03-16-2010, 09:24 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Turn off the water, pull out the cartridge and shake it to see if the balancing spool is functioning properly. It should rattle.
Journeyman Plumber
Old 03-16-2010, 09:26 AM   #3
Thanks for the quick reply. I'm not sure what the cartridge is? Can you point me in the right direction to see a diagram of a typical mixing valve?
thanks again.
Old 03-16-2010, 10:00 AM   #4
HEre is teh exploded parts view of the shower set-up that I have.
http://www.moen.com/shared/pdf/l82691pt.pdf
Does the cartridge just slide out or are there pins holding it in place?
Thanks for the information. If anybody else has anything to add or any other ideas I would appreciate it.
Thanks again
Old 03-16-2010, 04:36 PM   #5
DIY staff
Rewards Points: 7,174
There is a horse shoe shaped clip that lifts out---The cartridge pulls straight out--usually you will need the help of a Moen cartridge puller(they are sold where ever Moen parts are sold)
Old 03-17-2010, 08:03 AM   #6
You think that a home depot or Lowes would have this "Cartridge Puller"
Old 03-17-2010, 09:02 AM   #7
Doing it myself
Alan's Avatar
I use channel locks to grab ahold of the brass stem and wiggle while I pull. It's hard but you can usually get it, especially if it's not really old.
Journeyman Plumber
Old 03-17-2010, 09:36 AM   #8
DIY staff
Depot has it Loews too I would guess. It's also a good practice to clean up the hole with a bit of sand paper rolled up like a pencil. Some times the hole has a bit of crud build up that can damage the new cartridge.....Mike...
Edit--Use the puller---Alan is a pro and knows what he can get away with before the shaft snaps--You do not.--Mike--
Old 03-17-2010, 01:19 PM   #9
Rewards Points: 352
Any chance the problem is in the cold water shutoff?
plumberinlaw is offline   Reply With Quote
Old 03-17-2010, 03:56 PM   #10
Nahh. I wasn't getting any cold water to the shower head so I installed a shutoff valve on the cold line before the mixing valve as a check. There is water there and at decent flow rate as well.
I'm stumped.
Old 03-17-2010, 04:25 PM   #11
DIY staff
Apex---When you pull that cartridge out--Instead of turning the water off to the whole house---
Shut the hot water off at your water heater and the cold using your new shut off----
That will give you a chance to test the cold water flow--and maybe blast loose any debris that may be clogging up your cold water line---Mike---
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
