No Cold Water From The Kitchen Sink Only. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By jmon
  • 1 Post By SeniorSitizen
Old 01-10-2017, 07:30 AM   #1
Rewards Points: 4
No cold water from the kitchen sink only.
Cold water is coming from all other faucets in the house.
We thought maybe it froze. Weather was cold, -20 degrees celcius, but warmer now. -1.
We replaced Moen Cartridge but still no cold water.
Thanks, Julian
julian_s is offline   Reply With Quote
Old 01-10-2017, 07:34 AM   #2
Rewards Points: 274
Re: No cold water from the kitchen sink only.
I agree, still frozen somewhere.
Sometimes kitchen pipes are run in an outside wall. Open doors under sink let warm air in. Use a lightbulb for more heat.
Hope you get it thawed out soon with no damage.
Bud9051 likes this.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
BlackTiger (01-10-2017)
Old 01-10-2017, 07:36 AM   #3
Rewards Points: 4
Thanks for the response.
The thing is our pipes are not run in an outside wall, and we haven't had an issue with it in the past.
Old 01-10-2017, 08:38 AM   #4
Rewards Points: 1,220
Determine if there is cold water flow from the under sink shut off valve through the cold water supply line to the faucet. If there is, debris may be affecting the new cartridge function.
tstex likes this.
Old 01-10-2017, 02:42 PM   #5
Rewards Points: 3,874
After they go through the floor where do they go, basement or crawlspace? Very common for a bit of air leakage between house and foundation to blow cold air in several feet reaching water pipes.
Bud
Bud9051 is offline   Reply With Quote
Washing machine making "glugging noise"; kitchen sink backing up; bad smells; UGH KDG Plumbing 5 01-04-2015 06:27 PM
no hot water at kitchen faucet....all others are fine. ideas? tarheelblue Plumbing 10 12-28-2014 11:55 PM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
