No Cold Water In Kitchen Sink, But Everywhere Else..Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2010, 09:57 AM   #1
Lightbulb
No cold water in Kitchen Sink, but everywhere else..Help
I have no cold water in my kitchen sink, but at the same time the water stopped working on my garage tap as well. Some have said that it sounds as though I turned off a valve, but I didn't, could it be possible that the pipes are frozen? Does one have anything to do with the other? And if it matters, I have a bathroom and laundry room all on the same level and they both receive cold water, please help????
Jerziep is offline   Reply With Quote
Old 06-04-2010, 12:19 PM   #2
Next Time...New Build
Rewards Points: 150
Not sure where you are located but frozen pipes in June would be tough.
Start in the basement and trace the cold lines from your sink to the source. There could be a shutoff somewhere that is closed.
RickyBobby is offline   Reply With Quote
Old 06-04-2010, 12:25 PM   #3
Thanks Rickybobby, I didn't really think it was frozen pipes considering that I am in NJ and it is close to 90 degress today. But I will try and trace the pipes and look for a shut off.
Old 06-05-2010, 10:07 AM   #4
Handyman
Rewards Points: 512
Its possible that you have mini-ball shut off valves under the sink (the silver- 1/4 turn valves) Someone may have inadvertantly pushed something against it and shut the supply closed. Just a thought
canadaclub is offline   Reply With Quote
Old 06-06-2010, 10:03 AM   #5
Owner
LateralConcepts's Avatar
Is it that you're not getting running water at all or that the water is just not cold?
LateralConcepts is offline   Reply With Quote
Old 06-06-2010, 10:20 AM   #6
Handyman
Rewards Points: 512
Sounds like the OP means no water at all. I have seen lots of homes where the shutoff under the sink also controls the garage. Weird, I know
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 12:21 PM
Kitchen Sink water pressure johnrad Plumbing 1 11-04-2009 03:51 AM
Water Shuts off at sink... Help Please Spud1 Plumbing 2 08-24-2007 01:31 PM
