No Cold Water Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2012, 07:08 PM   #1
No cold water flow
We have no cold water flow in our home. Hot water flow is great. Turn on cold water from faucet and it barely drips in the kitchen. Have two baths and and cold water has a steady low stream. Neither of the toilets will fill. Have a whole house filter and have changed it and replaced the whole assembly. Not sure what else to do. The home is a mobile home and the pipes are grey plastic.
Misunderstood is offline   Reply With Quote
Old 08-05-2012, 07:11 PM   #2
Rewards Points: 1,766
look for a valve that is partially closed; hard to imagine how else you could have strong hot water flow and no cold at all fixtures.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Misunderstood (08-06-2012)
Old 08-05-2012, 07:14 PM   #3
Rewards Points: 14,306
Gary plastic pipe tells me it's Quest, thousands of law sutes againt them because of the pipes bursting.
Is the pump running none stop, or if you on city water is the meter running and nothings on?
Anyone been working on the plumbing and left a valve off?
Old 08-05-2012, 07:26 PM   #4
First thought was a leak but didn't find one. Had someone check the meter and it was ok. All valves are open. When I replaced the whole house filter let the line coming in run into a bucket and seemed to be flowing strong. Really appreciate everyone's help! Hoping to be able to fix it without having to hire a plumber.
Old 08-05-2012, 08:18 PM   #5
biggles's Avatar
the only thing you touched was the filter is it in backwards has to be right there
The Following User Says Thank You to biggles For This Useful Post:
Old 08-06-2012, 06:46 AM   #6
Rewards Points: 1,216
If the water flowed out good at the filter then troubleshooting should be from the filter into the trailer. Start at the filter go from there. City or well water?
COLDIRON is offline   Reply With Quote
Old 08-06-2012, 02:13 PM   #7
We have city water and it's very hard water. Could a pipe be blocked? Like I said hot water comes out fine but when the heater fills back up it takes a long time. The faucet outside has a little flow better than anywhere else but still is low compared to what it was.
Old 08-06-2012, 03:44 PM   #8
Sounds like a partial blockage in the main somewhere after the filter.
When you change the filter there could be a bunch of stuff in the outlet side of the pipe.
You need to check the pressure at the main before the filter and the closest place after the filter.
Hot water coming through cold water line mrdojo Plumbing 0 01-26-2012 04:19 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
