This is an odd one for me - I have had issues with this set of pipes freezing in my house before - or at least I thought they were freezing. This year its different. This morning I went into my washroom and just about burnt my
on my toilet. Hot water in the toilet? That's a new one. I shut of the valve and the heat dissipated - good. Now onto the real problem - no cold water at all. Hot water seems to flow sort of freely - the odd part is that when I opened the access panel to the pipes, both the cold and hot pipes feel extremely hot to the touch - as though I have no cold water running through the pipes at all. There is also absolutely no water coming out when I turn any cold taps. Water only flows when the hot taps are on. To clarify, the toilet isn't filling up quickly with hot water it's just sort of seeping in.
In past year I have run into trouble and have solved it by trying to force heat near the pipes and running the water until the blockage was removed - this hasn't seemed to have worked so far, and it happened in warmer temperature than the last freezings (still extremely cold here though, mind you - Winnipeg MB Canada).
Any thoughts? Could it be a valve that is finally given up the ghost? I can't come up with anything other than I think I know the general source of the blockage since the pipes work fine to a certain point and then are problematic from my second story bathtub to my third story bathroom - both of which share the same plumbing.
Any and all help is appreciated.
