No Cold Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2010, 01:19 PM   #1
Post
No Cold Water
I have a 3 story building and currently there is no cold water in bathroom sink on the 2nd floor. My first concern was frozen pipes as the temperature dropped to 10 degrees. The pipes run along an exterior wall, but are inside the insulation and have additional foam insulation.
I believe the same pipe runs to the bathroom on the 3rd floor, which is working fine. (I can see the joint where the pipe splits, 1 end going to the faucet, the other end going up). The cold water is still working in the shower.
What else could be preventing the water? What can I do to check for problems? (This problem occurred suddenly and all valves remain open.)
Demolisher555 is offline   Reply With Quote
Old 12-08-2010, 01:38 PM   #2
And Still Learning
Sounds like ice. Are the pipes running in an interior or exterior wall. Is the building heated?
Know It ALL is offline   Reply With Quote
Old 12-08-2010, 03:24 PM   #3
The pipes are on an exterior wall, but inside the insulation.
It appears to be the same pipe feeding the bathroom on each floor though. So how would a frozen pipe effect only the middle floor?
Yes the building is heated, it has been at 70 degrees.
Old 12-08-2010, 09:30 PM   #4
FTRR
common sense
Probably not frozen could be a bad valve.
FamilyTreeRemod is offline   Reply With Quote
Old 12-08-2010, 11:41 PM   #5
Rewards Points: 352
perhaps the angle stop for the lav is plugged
plumberinlaw is offline   Reply With Quote
Old 12-09-2010, 06:06 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... Probably because it's frozen along the lateral run, after the vertical run....
Tags
frozen pipes , no water at spigot , pipes , plumbin
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 05:00 PM
No cold water!! Hot coming out in the cold faucet! HELP Marilynjp Plumbing 6 01-04-2010 06:40 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
