NO Bath Water Running!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2005, 04:18 PM   #1
Unhappy
NO bath water running!!!
Help! We have a single knob tub and shower faucet that is able to rotate 360 degrees without any tension and there is no water coming out of the faucet spout. It worked the way it always did this morning when I gave my girls their bath (which was you never knew which way you had to move the lever to find the hot water). Now it doesn't matter which way you turn the knob there is only a steady stream of water leaking from the spout about the size of a strand of yarn.
Any suggestions will help
Thanks in Advance
rath is offline   Reply With Quote
Old 09-09-2005, 01:13 PM   #2
Fixed it already
Well, I panicked and called my husband at work and called my dad and went to home depot and found my answer, it was the valve. But it's fixed now .
Running Water makes pipes moan MikeRatliff Plumbing 2 01-25-2007 07:47 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Old Water Supply Lines in Kitchen and Bath Faucets skittlzski Plumbing 2 08-08-2006 10:13 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
