No Anode In Water Heater. Add One? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2014, 08:31 PM   #1
Rewards Points: 6
No anode in water heater. Add one?
Hello all, first time here. Awesome place...
I was getting a rotten egg smell from the shower after a few minutes and did a little research which led me to the anode rod. House was a new build for us in 08. I looked for the anode in the usual location to no avail. There is a T/P relief valve where it should go. I pulled the valve just to be sure and sure enough no anode to be found.
I have an anode that will fit there and I could relocate the T/P valve to the side of the heater no problem. Question is would it be worth it to add the anode after all these years with out one? Or wait for the need to replace and just flush and sanitize the tank with peroxide and or bleach as I have heard people do to kill any critters in there?
Thanks folks, again glad to find this place.
jj04taco is offline   Reply With Quote
Old 10-01-2014, 08:34 PM   #2
Rewards Points: 582
What is the manufacturer of the water heater?
Dan
djlandkpl is offline   Reply With Quote
Old 10-01-2014, 08:34 PM   #3
Rewards Points: 2,720
Give us the make and model number on your tank.
Old 10-01-2014, 11:03 PM   #4
Rewards Points: 322
There is always an anode rod. Do you have a Bradford White? They usually attach the rod to the cold inlet nipple so from the outside it looks like there is not a rod.
SHR Plumber is online now   Reply With Quote
Old 10-01-2014, 11:36 PM   #5
Rewards Points: 6
It's an AO Smith GCV 50 200. The diagram shows Anodes in a few places. I had to get a bendable anode because of clearance from above. I suppose I could check below the inlet and outlets.
hotwater.com has some info.
Old 10-02-2014, 07:27 AM   #6
Rewards Points: 582
I found a diagram online. The anode is part of the outlet. You will need a different rod as it has to incorporate the outlet. It's like the one SHRPlumber posted.
Dan
Old 10-02-2014, 04:22 PM   #7
Rewards Points: 6
Can I use any anode rod from any manufacturer designed for an outlet? It seems that they all have standard fittings and threads.
It will have to be flexable or segmented as I only have 21 1/2" of clearance above the heater.
Old 10-02-2014, 06:40 PM   #8
Rewards Points: 582
I would think you could. Can be 100% certain.
Dan
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Heater Anode Rod NitroNate Plumbing 3 07-20-2014 04:03 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
