Nicked Pex With Drill, Do I Need To Redo This Connection? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2013, 12:35 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Nicked pex with drill, do I need to redo this connection?
Just a tiny little nic, that pex also has a black liner inside, some kind of rubber membrane I think, I only nicked maybe half way through the plastic. Should I cut and redo this connection? I don't want to add a joiner if I don't have to, especially given this is near the electrical panel, but if there is a risk of that nic eventually leaking then I'm better off doing it... what do you think?
Old 08-10-2013, 07:06 AM   #2
Rewards Points: 13,740
Why take the chance?
(it's called a coupling)
Best drill bit for old concrete johnjack11 Concrete, Stone & Masonry 22 03-14-2012 03:27 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 06:07 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
