Old 07-27-2008, 11:09 PM   #1
analogmusicman's Avatar
Default nicked copper pipe
I was cutting some wallboard out with my recip. saw and hit a 1/2 in. copper pipe. (no,it doesn't leak) my question is, just how deep does a nick in copper tube have to be before you should do something like cut out the nicked part and put in a coupling? I ask because copper tube doesn't seem to be all that thick. (like galv. pipe which is heftier'n a female Russian weightlifter)
tnx,
analogmusicman is offline   Reply With Quote
Old 07-28-2008, 12:29 AM   #2
In all liklihood, you have nothing to worry about. If the pipe isn't leaking now, it prolly won't leak for a gazillion years. Where I live, it was common practice for plumbers to use a round file to file out the ID of dimpled couplings so that they could be used as slip couplings. So, there are thousands of couplings in Winnipeg, Manitoba that have a very thin wall thickness in one small spot, but yet none of those couplings leak. So, chances are your nick will never leak either.
However, if you'd feel better fixing it now, here are two ways to do that:
If you can drain that pipe, I'd apply some strong hydrochloric acid (muriatic acid, maybe) to the outside of the pipe where the nick is, clean that acid off with water, then apply any alcohol (cuz water is soluble in alcohols) and wipe the alcohol up with a paper towel (thereby removing any residual water).
Immediately apply a soldering flux to the bare copper metal, heat the pipe and apply a dab of solder over that nick.
That'll last till the cows come home.
Alternatively, you could drain the line, sand the pipe OD at the nick and the ID of a copper slip coupling, cut the pipe at the nick and solder the slip coupling in place over that nick.
In some areas you can't buy true slip couplings. A true slip coupling will not have any dimple on it. If you can only buy couplings with dimples DO NOT use a file to remove copper from the ID of the coupling where the dimple is. This severely weakens the coupling at that spot. Instead, slip the coupling over a pipe of a smaller ID and hammer on the coupling to remove the dimple from it. That way, you still have the full wall thickness of copper where the dimple was. THEN, and only then, use the coupling as a slip coupling.
Nestor_Kelebay is offline   Reply With Quote
Old 07-28-2008, 06:38 PM   #3
Send a message via AIM to Marlin
Or if for some reason they don't sell slip couplings just order them... You would have to have a real hardass of an inspector to check your couplings for a dimple.
Marlin is offline   Reply With Quote
Old 07-28-2008, 10:54 PM   #4
Licensed Master Plumber
mstplumber's Avatar
I would fix it right, with a coupling. You are right, most copper isn't very thick. The Home Depot or Lowe's stores in my area sell slip couplings. If you can solder, this will be a simple repair.
You can do it!
Mstplumber
FREE Plumbing Mini Course:How To Unclog A Toilet
mstplumber is offline   Reply With Quote
More On This Topic
What is Copper Sweating?
What is Copper Sweating? by Expert Village
Hey everybody, Don Golden here for Expert Village and have I got a topic for you. Okay, this is all about copper. No, not stuff you want to wear, the jewelry on your hands or wrists. It's about copper piping. Why do you care about copper piping? It is... Read More »
Hey everybody Don Golden for Expert Village and we're back with copper piping and we've cleaned the inside and the outside of the pipe that we're going to be soldering today or sweating and if you're going to use this copper as a true water application... Read More »
Hey everybody Don Golden for Expert Village and we are having fun with copper today, copper piping. We just put this joint together and I felt it was my duty to show you a new technology that really makes this even easier and it is pretty easy as it is... Read More »
Even though a relaxing campfire at the end of a day in the woods is the perfect end to the day, you can spice it up by adding some colorful flames to a campfire. There are various products on the market that do the same thing, but you might be able to... Read More »
Hey people Don Golden back again. For Expert Village and we're working with copper pipe today. And we just finish cleaning this piece now. I want to show you how to clean the inside. We are going to use another tool. We already use the emery cloth. So, I... Read More »
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 08:25 PM
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 10:39 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 12:55 PM
Can I Extend the 3/4" Copper Pipe? froddan Plumbing 2 07-23-2007 06:03 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 09:53 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
