Has anyone seen a nice way of bringing a water line out of a wall for a refrigerator. You can just drill a hole and pull the line through, of course, but I was wondering if there was a nicer way of doing it.
Thanks. I'll try to find one at Home Depot. This should make for a much nicer water point than what I've seen before. I wish I had known about these types of trim kits when I redid my plumbing. I have a hot and cold water spigot just sticking out of the wall for my washer.
Any of you same fellers know a good way to connect a garden hose to a water supply? There are two ends on the garden hose, and I can screw them together, but that doesn't get the job done.
I found a water point at Home Depot, similar to the one TheEPlumber posted the photo of. In the instruction it depicts this little faucet screwing right onto a threaded fitting atop a 1/2 copper pipe. Is that the best way to do this, or can I rout a flexible 3/8 tube and attach it. Are there such fittings? The water I intend to send to the refrigerator comes from a RO water filter, not straight utility water, and the filtered water line coming out of the system is 3/8. I plan to split it, sending it to both the little sink faucet and the refrigerator.
horseating, This is a recording, " USE ONLY PLASTIC IN CONTACT FROM THE RO SORCE TO THE END USE". There's a reason for this please listen to the advise given.
I know. Grassyplumber just said that. That's why I thanked him. The line coming from the RO system is pex, I figure I'll rout a pex line to the ice maker outlet box, but the valve on the ice maker box is brass -- or at least all the ones I've found are. I might also guess that there are non-plastic components in the ice maker.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
