NIBCO Hose Bib Valve Stem Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2009, 09:57 PM   #1
NIBCO hose bib valve stem handle
I have a 30+ year old NIBCO hose bib. I need to replace the metal handle. The diameter at the top of the valve stem is 5/16". There are 16 little sprockets on the top of the valve stem. Can anyone tell me where I can get an original handle? The generic replacement handles at the hardware stores don't fit. Thank you.
shape is offline   Reply With Quote
Old 02-27-2009, 10:57 PM   #2
The "sprockets" is what is called a spline. You may need to go to a surplus shop or a demolition supply place.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-28-2009, 06:23 AM   #3
What he said, but you might find a generic type at home or hardware stores. Generally you have to replace the bib.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Bleed valve on hose bib napostol Plumbing 4 11-15-2008 04:36 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Trying to loosen stem valve nut mjay Plumbing 1 05-03-2006 11:14 PM
