Next Generation Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2009, 11:00 PM   #1
Rewards Points: 1,088
But is it better than gas? How much will the unit and install cost though?
http://www.geappliances.com/products...ater/index.htm
handy man88 is offline   Reply With Quote
Old 09-23-2009, 07:08 AM   #2
Since it said "heat pump" water heater, my quess is it is VERY expensive to install. While more efficient than electric, so is the plan old gas heater, and I suspect payback will take a long time.
Old 09-23-2009, 08:12 AM   #3
It shouldn't be any more expensive to install than a standard water heater. Everything is contained on the unit.
jerryh3 is offline   Reply With Quote
Old 09-23-2009, 09:39 AM   #4
Will it dehumidify the basement?
VelvetFoot is offline   Reply With Quote
Old 09-23-2009, 09:52 AM   #5
I was thinking that also. Be nice if it did. I'm sure they'll be some type of condesate drain unless they found a way to pump it into the tank.
Old 09-23-2009, 10:05 AM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Pumping the condensate into the tank would contaminate the water.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-23-2009, 10:10 AM   #7
Would it make the basement colder though, since it's extracting heat from the air? My basement gets pretty cold in the winter.
Old 09-23-2009, 11:12 AM   #8
Never thought of that. So it will have to have some type of drain?
Old 09-23-2009, 02:41 PM   #9
I believe so. I've been looking at Rheem's new heat pump water heater (HP-50) and they mention a condensate drain.
HautingLu is offline   Reply With Quote
Old 09-23-2009, 05:07 PM   #10
I'd like to see the price on it. I just saw it yesterday in the This Old House magazine and got interested. If it qualifies for the federal tax credit it may be worth looking at.
Old 09-23-2009, 05:08 PM   #11
Probably make it a little colder. It needs to extract the heat from somewhere.
Old 09-23-2009, 05:09 PM   #12
K.M.G's Avatar
Rewards Points: 109
Wow that thing looks like it will sell for $3000
K.M.G is offline   Reply With Quote
Old 09-23-2009, 05:32 PM   #13
The coolest thing about this unit is that it has a vacation mode which will probably shut off the heating function, and maybe even the supply valve to prevent potential flooding if something goes wrong.
Old 09-23-2009, 10:11 PM   #14
I have that now, called a breaker switch & water shut-off
Old 09-23-2009, 11:59 PM   #15
Unfortunately, your breaker switch doesn't have a timer like this one.
"Vacation or Away Setting Why pay to keep hot water available at home when no one is there to use it? With the Vacation or Away Setting, the water heater drops the water temperature down to 50F and uses the most efficient heating mode, eHeat, to conserve energy while the heater is sitting idle. Simply enter the number of days you'll be away, and the water heater will automatically resume heating one day before your return, so that hot water is ready and waiting for you."
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
