"Next Bunch Of Questions???" - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2012, 09:43 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
"Next bunch of questions???"
Originally Posted by oh'mike View Post
No drywall in a wet area!!! even behind the cement backer----Yikes!---You have been here to long not to know that!!
See....Mike made me do it.....
Ok...so the real question here....best way to do a shower?
The way I see it....3 options...hot mop, membrain, Kerdi.
Some of the shower install instructions I saw showed green board being used...then hardi backer on top of that...others, just hardi backer.
On the Kerdi instructions, they show their stuff going on top of green board.....
At this point....I'm leaning towards Kerdi....the pre-cut pans will not work for me...but they have the rolls of the same stuff that you can cut to shape....hence, I'm thinking standard mortar base....hardi backer down the walls...Kerdi material on the bottom and sides...
Or...same as above but rubber membrain for the pan.
The Kerdi looks to be less labor...but more expensive....my time is free....but I only want to do it once...
So...which is it?
Need a bunch of dedicated circuits in one area Red Squirrel Electrical 9 01-15-2011 04:17 PM
Removing the old Brady Bunch Kitchen light victor07 Building & Construction 4 11-26-2010 04:42 PM
I'll have a bunch of easy questions for you gailquilter2 Electrical 4 05-12-2010 08:00 AM
Why did my water heater dump or spit out a bunch of water and now is fine? Ptron Plumbing 7 05-05-2010 01:39 PM
Need some advice for a bunch of things. ingeborgdot Home Theater 11 02-12-2009 07:48 AM
