Newbie Question About Crack In PVC Joint - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2007, 09:41 AM   #1
Rewards Points: 12
Newbie question about crack in PVC joint
Hey all newbie question. I noticed a leak in the ceiling of my den, and opened it up - appears a cracked PVC elbow coming from the toiliet flange in an upstairs bathroom ( directly above the leak ) is the source of the problem.
I've posted some pics of the elbow - it appears to me that the PVC elbow has been patched before. I had a general handyman who does a lot of work for me take a look at it, and he thinks that the entire toilet flange, PVC elbow, and a portion of PVC pipe need to be replaced.
My question is - a) Is it advisiable to repatch the PVC elbow ( it looks to be in pretty bad shape ), b) If i have to replace it, can i just replace the elbow and not all the other parts.
Linus....
Newbie question about crack in PVC joint-cimg0643-small.jpg   Newbie question about crack in PVC joint-cimg0644-small.jpg   Newbie question about crack in PVC joint-cimg0645-small.jpg   Newbie question about crack in PVC joint-cimg0646-small.jpg
LinusInPW is offline   Reply With Quote
Old 11-14-2007, 10:15 AM   #2
Bathtub Refinisher
It looks like the pvc elbow is attached to the old lead pipe. You would be better off to replace everything from the elbow to the toilet and be done once and for all. A band aid will fall off and you will have the same problem again. Probably did not want to hear that. If it would have been done RIGHT the last time you would not this problem now
Good Luck
Mike
tubguy is offline   Reply With Quote
Old 11-14-2007, 10:52 AM   #3
Rewards Points: 12
thks tubguy. Looking at your reply it appears the lead pipe was fused to the PVC coupling, and the crack is in the point in which where they join? Just want to understand why replacing the entire assembly would be the better option.(sorry if these question sound stupid, this is the first plumbing work i have ever had to deal with )
Thanks again
Linus
Old 11-14-2007, 11:04 AM   #4
Bathtub Refinisher
The problem with lead pipe is how to make a water tight connection to pvc that will not EVER give any further problem. Which is what you have going on now. I own rental property and have seen band aid type repairs that didn't last. Maybe temporary repairs that were forgot about. If it is not done right now and the wall is repaired what happens when it leaks agian. Water damage is expensive to repair. That is what is going on now. If you have above average diy skills you can make the repair yourself. Or hire a pro.
Old 11-14-2007, 11:40 AM   #5
Rewards Points: 12
Mike.
Thx - got it. Im going to replace everything
With regards to the orginal work being pretty crappy - This appears to be the orginal piping ( house was built in 1980 ). Is there any reason they used lead, and not a PVC based toilet flange? I cant see how lead would be cheaper than PVC
Regards
Linus
Old 11-14-2007, 01:57 PM   #6
Rewards Points: 150
Should be a fairly easy DIY thing, just a few hours of work. You'll need a PVC flange, a closet bend, a coupling a piece of pipe and a new wax ring. You'll need to open up the ceiling a bit more, remove the toilet, use cable saw to cut the pipe, and take out the old flange, elbow and all. glue pipe into closet bend, measure and cut the pipe and then couple it to old pipe so closet bend aligns with hole in floor. Glue in the flange, secure to floor, clean old wax off toilet, and reinstall using new wax ring. Check for leaks avbove and below, and if it looks good after 2-3 days, close up the ceiling and caulk around the toilet.
scorrpio is offline   Reply With Quote
Old 11-16-2007, 07:28 PM   #7
Rewards Points: 12
ok removed the flange ( it was it terrible shape ), and replaced it with a PVC flange. Problem was the lead flange was a short size, so we had to cut the elbow a bit about 1 inch so it would fit in place
My handyman attached it to the orginal PVC pipe using a coupling, but it now seems to leak at the coupling points. ( see picture ).
how would you recommend fixing this? Would any type of PVC/putty around the pipes be a long term solution.
Old 11-16-2007, 11:14 PM   #8
Send a message via AIM to Marlin
If you have a schedule 40 PVC coupling glued to schedule 40 PVC pipe which has been properly cut, cleaned and glued their is no reason why it should leak. Your handyman simply screwed up somewhere. You will need to cut the coupling off and go back further on the pipe, their is no easy way around it.
Marlin is offline   Reply With Quote
Old 11-16-2007, 11:25 PM   #9
Bathtub Refinisher
Marlin is right
Measure twice-cut once. Cut it out and replace. you are almost done..don't give up now
Mike
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 09:12 AM
Newbie Insulation Question: Cathedral Ceiling Battman328 Building & Construction 5 01-24-2008 05:37 PM
Newbie Question bjp Introductions 2 10-09-2006 02:37 AM
joint compound question golfer General DIY Discussions 3 01-09-2006 06:19 AM
