Newbie In A Bind - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2012, 02:15 PM   #1
Newbie in a bind
Greetings All,
I am new to the forum and an hoping I can get some help.
I am in the middle of changing out my Delta 1400 Series cartridge in my shower and for the life of me I cannot remove the brass bonnet (nut) holding the cartridge in.
A friend implied that it may have welded itself on over the years and I may have to purchase an entire valve body and rip half the tiles off to replace.
Any tricks on getting this bonnet off.
I have tried channels, pipe wrenches, penetrant and even a little heat.
Exaspirated!
Plumb crazy is offline   Reply With Quote
Old 11-17-2012, 04:53 PM   #2
Plumber
Try more heat, and if that doesnt work use a mini hacksaw to cut the bonnet off.
DidIDoThat is offline   Reply With Quote
Old 11-17-2012, 04:57 PM   #3
Rewards Points: 12,868
Got a picture?
Old 11-17-2012, 09:10 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 840
Wouldn't that mean that you would have to replace the rough-in valve?
Or, do you mean just cut the collar of the bonnet?
ddawg16 is online now   Reply With Quote
Old 11-17-2012, 09:42 PM   #5
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet
Old 11-17-2012, 09:46 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 840
I don't have one of those....but I found the thread interesting.....
I like the trick of using emmery cloth as a friction device...
Old 11-18-2012, 08:52 AM   #7
Many thanks for your replies.
I have gone to HD and purchased a new valve body and will call a pro in to rough it in.
Not looking forward to ripping the tiles and backboard off however this puppy is simply not budging and I fear I will rip the whole assembly out of the wall.
Alabama Newbie JBozeman Introductions 4 04-07-2012 05:04 PM
newbie here pam2 Introductions 2 10-02-2011 07:21 PM
Newbie iklingenberger Introductions 2 11-16-2010 06:16 PM
Newbie from landsdale jackwhite Introductions 0 09-23-2010 02:12 AM
Hello, newbie here from the heartland... Mr. Michael Introductions 8 01-27-2007 12:54 PM
