Newb Needs Help With Shower Knob Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2012, 07:27 PM   #1
mackdiesel's Avatar
Newb needs help with shower knob repair
Okay the first pic is the knob i took off. That screw in the middle is the issue. When i loosened the screw and tried to put it all back together i quickly found out that half of that screw is sitting back in the sleeve....i have no knob for my shower/tub (using needle nose to improvise) i just dont want to have to take apart any plumbing to repair this. Help, please, thanks...
Newb needs help with shower knob repair-image-2455356760.jpg   Newb needs help with shower knob repair-image-3948189884.jpg   Newb needs help with shower knob repair-image-950166177.jpg   Newb needs help with shower knob repair-image-4227238410.jpg
mackdiesel is offline   Reply With Quote
Old 05-20-2012, 08:36 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 674
Your best bet is to replace the cartridge.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (05-20-2012)
Old 05-20-2012, 08:41 PM   #3
Rewards Points: 582
yep what eplumber said..replace cartridge only good way to repair.. its a moen...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 05-21-2012, 03:20 PM   #4
mackdiesel's Avatar
How much would a plumber charge to do this?? I know this is a DIY site but, man...that piping is fragile as hell and im afraid im going to wreck it up. I can't even find a serial # or model # for that cartridge replacement.
Old 05-21-2012, 05:12 PM   #5
Rewards Points: 1,296
Replacing the cartridge is easy. That little tab sticking up out of the brass tube is the clip that holds the cart in place pull straight up on it to remove the horseshoe shape clip. Once that is done grip the cartridge with some pliers and pull straight out. Slide the new one back in and replace the clip.
Noen designed a great cartridge that never realy needed updating so it is universaly used on a lot o their products. In fact that model of cartridge is the same one that Moen used back when they invented water. Check with any big box store or plumbing supply house or a replacement.
What makes you think your pipes are fragile? Coper is tougher than you think.
danpik is offline   Reply With Quote
Old 05-21-2012, 06:18 PM   #6
You need a moen 1200 replacement cartridge.Any plumbing supply house will have one.
plumberman134 is offline   Reply With Quote
The Following User Says Thank You to plumberman134 For This Useful Post:
ben's plumbing (05-21-2012)
Old 05-21-2012, 09:21 PM   #7
mackdiesel's Avatar
Thanks to everyone that has replied and helped out. Hopefully i can get this fix by tommorow.
Old 05-22-2012, 03:28 PM   #8
mackdiesel's Avatar
Having a hard time busting that tab out of the cartridge. Using a needle nose to wiggle it out of there...sprayed some wd 40, still wont budge. I dont want to get to crazy because im fearful that i will break it off or snap it in half, then what....?
Delta Monitor shower repair. Jakkkk Plumbing 7 10-30-2011 08:53 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Moen 3 knob faucet repair? blue82001 Plumbing 3 06-16-2006 11:32 AM
Shower Door Repair startingreferralbiz Plumbing 2 01-11-2006 07:00 AM
