Old 06-23-2012, 10:21 AM   #1
Question
New Water Main Tap
I'm purchasing a house that has a point well in the basement. This is apparently not up to code. City water is available at the street (90 feet) and I figure I should tap in rather than paying to drill a new well. Because I'm broke and the County's tap/hook fee is $7,300 I need to do the work myself. Can anyone provide a) a list of parts I will need and/or b) A description of how it is done?
Woodsman165 is offline   Reply With Quote
Old 06-23-2012, 10:49 AM   #2
MarginallyQualified
New Water Main Tap
If this means that you haven't bought the house yet... then DON'T.
Or at least not until AFTER it is connected to the city water service.
Can anyone provide... or b) A description of how it is done?
You tell the seller "no deal" until the trench is dug, the pipe is laid,
the meter and valve are set and the water is flowing.
(also check on the sewer service issues)
The seller will want to get a higher price for the property afterward.
Work that out with your lender and the appraiser.
ETA: fwiw $7300 sounds like a criminally high price for this job.
Do you have an attorney representing you in this purchase?
If not... get one immediately.
Tags
water hook up, water main, water meter
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 08:46 AM
