-   -   New water line (http://www.diychatroom.com/f7/new-water-line-31041/)
dh9318 11-01-2008 07:26 PM
New water line
iI am having a new home built and I am going to put the water line from the meter to a cutoff valve myself. The water line will be about 200 feet. I need to know what type of line to install. I have heard of PEP but I am not sure if that is the correct type. Any help is appreciated.:thumbsup:
Mike Swearingen 11-01-2008 07:37 PM
I'm not a pro plumber, just an old DIYer.
I would run 1.25" Schedule 40 PVC for a 200' supply line for volume well below the local frost line (check with your Building Inspection Department for local code first).
Mike
Marvin Gardens 11-01-2008 08:47 PM
Pex is allowed and it easy to install.
Don't let any of it be exposed to sunlight for more than 30 days total and don't have any connections underground. If you do have connections then use sharkbite connections which are approved for burial.
No need to use any conduit.
You will have to use at least 3/4" and those are big rolls. I just take the roll, connect it to the source, roll it out in the trench and then cut it off at the end. Make sure you leave more than you need to get to the shut off in the house so that you don't have to be doing a lot of splicing. Every splice will decrease the flow and 90's are the worst.
