New Water Heater Supply Lines Electrolysis Proof? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2011, 10:28 PM   #1
Rewards Points: 682
New water heater supply lines electrolysis proof?
I've heard the new flex water lines for water heaters have plastic liners and are proof against electrolysis. Is this true?
darsunt is offline   Reply With Quote
Old 09-05-2011, 02:22 AM   #2
Rewards Points: 6,652
What makes you believe that it is happening with PEX, CPVC, PVC? Electrolosis can only happen between two metals with differing dielectric properties.
Old 09-05-2011, 11:57 AM   #3
Rewards Points: 682
The lines are traditional flexible copper, but you can see some plastic lining inside.
Old 09-05-2011, 12:24 PM   #4
So, How or where did you hear that electrolysis can happen in Pex? Do you even know what electrolysis is?
Old 09-05-2011, 02:37 PM   #5
Wink
yes they work well
they work like diaelectric unions,,,
we use them all the time... mostly the black brass craft brands...
master mark is offline   Reply With Quote
Old 09-05-2011, 06:38 PM   #6
Rewards Points: 682
The local plumber shop said they work well. Just double checking with you guys.
One less thing to worry about...
any problem with cold water branch before water heater? jasperjodo Plumbing 3 06-08-2011 08:01 AM
Water heater T&P plumbed to cold supply rjniles Plumbing 5 05-21-2011 04:42 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 07:01 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
