-   -   New water heater, hot water doesn't last long. (http://www.diychatroom.com/f7/new-water-heater-hot-water-doesnt-last-long-166183/)
dmlove67 12-11-2012 06:37 AM
I just replaced my 50 gallon gas water heater with a new GE 50 gallon gas water heater. I had to turn the thermostat all the way up. When I start a shower, the water is nice and hot. Less than 2 minutes into the shower, the water slowly gets cooler and I have to shut off the cold valve completely in order for the water to stay some what hot/warm. I called the technical service phone number and they're telling me that it sounds like it's operating correctly. My old water heater used to put out very hot water for a very long time and the thermostat was only half way turned up.
Any suggestions on what might be wrong??
:censored:
DexterII 12-11-2012 07:05 AM
The first thing that I would check is that the in and out plumbing is correct; cold water supply, from the street or well, should be connected to the port marked "COLD", and lines carry hot water to the points of use should be connected to the port marked "HOT".
dmlove67 12-11-2012 07:13 AM
That was the first thing I checked. They are connected correctly.
Ishmael 12-11-2012 07:40 AM
Who installed it?
Does this happen only at the shower, or does the hot water run out fairly quickly at all the fixtures? Run the shower and wait for it to get cool, then check the sink (hot only) in the same bathroom.
jmd87 12-11-2012 07:41 AM
If you have a thermometer that can read between 100-200 degrees F: Get a temperature of the water coming out the hot side only.
Are you sure you didn't turn the thermostat the wrong way? :laughing:
dmlove67 12-11-2012 07:45 AM
Originally Posted by Ishmael (Post 1070819)
Who installed it?
I installed it.
dmlove67 12-11-2012 07:46 AM
I'll check the temp with a thermometer when i get home from work. Pretty sure i turned the thermostat the right way, the arrow is pointing on the label that says "VERY HOT" :furious::laughing:
dmlove67 12-11-2012 07:48 AM
Who installed it?
I installed it. seems like it's only happening in the shower, but then again i don't think i've left the hot side of the sink on long enough to find out. i'll try that when i get home from work and see what happens.
Ishmael 12-11-2012 07:58 AM
Sometimes when you install a new water heater, scale and rust can flake off the inside of the pipes (where you're working) and find it's way into things.
Is it natural gas or propane?
dmlove67 12-11-2012 08:11 AM
It's natural gas.
dmlove67 12-11-2012 09:14 AM
Was thinking of checking the dip tube, but that should not be a problem considering it's a brand new water heater.
jagans 12-11-2012 09:45 AM
Efficiency
Is this a high efficiency heater, vented to PVC pipe with a blower on top, or just a standard hot water heater, vented into a chimney flue? Nice if you give enough info to attempt an assessment.
dmlove67 12-11-2012 10:07 AM
Sorry. Nothing vented to PVC. It's vented into a chimney flue. GE Model #: PG50T09AVH
DidIDoThat 12-11-2012 11:33 AM
1 Attachment(s)
This would be my bet.
It wouldn't be the first one to have a bad dip tube right out of the box.
It very simple to replace.
dmlove67 12-11-2012 11:44 AM
Thanks D. I was planning on checking that out first thing after work today. Hopefully that's all it is. If not, it's under warranty so I'll let GE handle it.
