New Water Heater. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2012, 12:13 PM   #1
New Water Heater.
I have got to replace my Water Heater, as Its leaking at the bottom, And thank goodness its in the Basement, Holding out as Long as I can, But Will get to it soon, The reason for the Post is I live in a 100+ Home with 2 stories and it takes for ever for Hot water to get up to the Upstairs shower, when I ran across the at the Hardware store,( Watts Premier 500800 Instant Hot Water Recirculating Pump with Timer), I did some research and it seems to work very well. I on the other hand will be installing it under my upstaires sink, I was just woundering if any of you have had to install one, It looks simple enough, The guy said it would pay for its self in a year, I have to wait almost 1 or 2 minutes for hot water in the shower and sink upstairs. Just looking for some input on this product.
Splinter2
splinter2 is offline   Reply With Quote
Old 11-27-2012, 12:19 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
I installed one about 2 years ago. Different brand, same idea. Mine uses a push button start instead of a timer. It works very well and saves a lot of water. I push the button and brush my teeth, water is hot by the time I am done brushing.
re: that water heater. If it is leaking from the bottom, I would not wait to change it. I have seen the results of what happens when they let go. Even in a basement they can cause a lot of damage.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 11-27-2012, 07:42 PM   #3
water Heater
Ya I better get on it while I have a Few days off. Thanks, I think I am also going to install the Recirculating Pump also.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
