New Vanity Sink Plumbing Doesnt Line Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2010, 02:23 PM   #1
New vanity sink plumbing doesnt line up
I am fixing my parents bathroom and just put in the new sink only to find that the drain is about 1.25" behind the j-trap. There is also no gap between them height wise so the idea of putting a flexi piece in there doesnt work out so well. Wondering what suggestions people have in this case.
Here is a picture to explain it better.
Handy Mandy is offline   Reply With Quote
Old 04-21-2010, 02:42 PM   #2
fabrk8r
fabrk8r's Avatar
It looks like you could discard the 45 degree ABS fitting on the wall stub and gain enough room for the P-trap.
Also, the tailpiece (gray vertical pipe w/pop-up connected to drain) can be cut off to a length that is more convenient for your P-trap connection.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-21-2010, 02:44 PM   #3
fabrk8r
fabrk8r's Avatar
Upon looking more closely at your picture I noticed that the tailpiece is actually too short. You may need to buy a longer tailpiece or add a short piece with a coupling.
Old 04-21-2010, 02:54 PM   #4
Thanks for responding so fast. So your thinking if I remove the abs piece I could just add a longer arm from the wall to the trap and twist it left to meet the tailpiece?
Old 04-21-2010, 03:22 PM   #5
fabrk8r
fabrk8r's Avatar
I don't think you'll need a longer trap arm after removing the ABS angle, just come straight out to the tailpiece and offset however much you need to using the P-trap.
Old 04-21-2010, 06:35 PM   #6
Since googling it didn't work I will ask you...How do I remove the ABS pipe?
Old 04-21-2010, 07:07 PM   #7
it looks like a screw/threaded on piece
The older I get the better I was
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 11:32 AM
Need advice for sink plumbing... dartsportsteve Plumbing 2 04-25-2009 08:56 AM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
replacing sink in corian vanity top jaybee General DIY Discussions 2 09-01-2007 03:08 PM
