New Vanity, Old Connections! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2011, 02:51 AM   #1
Question
New vanity, old connections!
I purchased a new vanity with a 3 hole 4" spread top and while I was there I bought new flexi lines to replace the two supply lines. I was glad to have thought of such an appropriate idea. Got home and ....! The old pipe sticks out of the wall and the ridgid line is attached differently. It looks like it is a band or nut around the pipe and then the angle stop is the last nut on the pipe. My house is almost 18 years old. If I turn off the main supply, remove the line, can the new flexi attach to the pipe or do I need an adapter of some sort?
Momalone is offline   Reply With Quote
Old 04-25-2011, 05:53 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,036
We need a picture
Coastal South Carolina
Old 04-25-2011, 07:22 AM   #3
Lightfoot's Avatar
Rewards Points: 272
Originally Posted by rjniles View Post
We need a picture
I agree. It would be helpful if we could "see" what you are describing.
Lightfoot is offline   Reply With Quote
Old 04-25-2011, 07:23 AM   #4
As suggested, a pic might help us, but 18 is not old in plumbing terms. Is it copper pipe?? What you describe sounds like a compression fitting. I assume it is a valve?? You may get lucky and be able to screw a new shutoff valve with the proper fitting in its' place. The normal fitting for a bathroom sink is a 3/8 compression fitting, with the faucet fittings being 1/2NPT
Old 04-25-2011, 11:04 AM   #5
Picture to follow
Thank you for the assistance on my first post! Out of desperation I never even thought about a photo...genius!
I am working on it and will get it up soon. Thank you so very much everyone!
Tags
bathroom , new vanity , plumbing , supply line
Building HVAC vent into bath vanity nolamar Carpentry 31 08-25-2011 03:33 PM
small gap between vanity and wall, how do i screw it in? cantgetenuff Building & Construction 8 03-09-2011 12:15 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 05:56 PM
HELP! Vanity tight squeeze 9728 Kitchen & Bath Remodeling 1 12-11-2009 03:53 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 02:12 PM
