New Vanity Faucet Is Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2013, 10:14 AM   #1
Rewards Points: 27
new vanity faucet is leaking
Hi all,
I'm trying to install a new faucet inside a new vanity. I've got everything hooked up in this order (top-to-bottom):
- Chrome drain plug / tailpiece assembly
- plumber's putty around plug
- sink
- large rubber donut washer
- plastic friction washer
- plastic nut
- plastic tailpiece
- drain extention
- P-trap
But it has a slow leak which comes out the underside of the plastic nut. I'm guessing it's due to a bad seal of the donut washer on the sink? Do I just need to use some teflon paste here?
Another note: the sink came with a foam washer which is supposed to go between the drain plug and the sink. I installed it this way first and had the same problem, so I removed the foam washer and used plumber's putty instead, but the problem persists.
kevind is offline   Reply With Quote
Old 03-03-2013, 11:33 AM   #2
Rewards Points: 446
take it back apart and carefully look at the bottom of the sink where it exits. there may be something there that is either keeping it from sealing good or a crack or large scratch the water can migrate out through. It's possible that the water is following the threads out past the gasket.
old_squid is offline   Reply With Quote
Old 03-03-2013, 11:47 AM   #3
Rewards Points: 14,290
Or just not enough putty was used or the nuts was not tight enough.
Old 03-03-2013, 12:19 PM   #4
DIY staff
Rewards Points: 7,174
^^^^ He has done this before^^^^^^
Feel the hole at the bottom of the sink with your finger--some times there is a rough spot---
Some times, I add a bead of silicone caulk to the gasket/sink bottom area before tightening-----
Old 03-03-2013, 12:21 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 902
I've gotten to the point of adding teflon paste on the tailpiece threads where the washer is. Shouldn't be needed but it has cut my call backs down....
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (03-03-2013)
Old 03-03-2013, 12:48 PM   #6
Rewards Points: 27
Okay, I checked out the bottom of the sink. Pics are attached. Not sure how clear it is, but it looks like the drain has a small notch on one side.
So....what to do now? I've already got the vanity bolted to the wall, and it's got several holes in it from drilling and cutting out sections to make room for the pipes. Can I salvage this without having to return the vanity?
new vanity faucet is leaking-img_3709.jpg   new vanity faucet is leaking-img_3710.jpg
Old 03-03-2013, 12:52 PM   #7
DIY staff
Sand or file that a bit---add silicone to the gasket/sink connection and give it a try---dry the area with a hair drier first----if that fails----take it back----but I believe you will make it work---
TheEplumber (03-03-2013)
New Moen Cartridge Is Still Leaking on Bathtub faucet rliu Plumbing 7 01-14-2013 08:49 AM
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 01:00 PM
Kitchen Faucet Is Leaking Sycamore Inn Plumbing 23 11-14-2011 03:49 PM
Bathroom Sink Faucet Leaking sgold33 Plumbing 1 01-17-2011 06:16 PM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 11:08 AM
