New Valves Won't Open. My Fault? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2012, 06:18 AM   #1
Unhappy
New valves won't open. My fault?
Alright I just replaced my bathroom sink and faucet had some problems but managed through. Turned my water back on and the went back to the bathroom sink to turn the valves on but they won't turn. The valves are brand new quarter turn Sharkbite stop valves. What could I have done wrong? Both valves are in exactly the same state, they just won't turn. Any help or ideas are appreciated.
bketros is offline   Reply With Quote
Old 06-07-2012, 06:33 AM   #2
DIY staff
Rewards Points: 7,174
Did they work before you installed them?
I've never used that brand,but they look like a high quality product---what have you tried?
I don't see how you could have caused them to seize.
Old 06-07-2012, 06:49 AM   #3
I thought they worked before hand but I don't actually remember checking them. What are the odds of both being bad from the store though?
Old 06-07-2012, 07:30 AM   #4
DIY staff
Not likely---often ball valves are very stiff to open the first time---I'm in the habit of working the valve a couple of times before I install---I bet you just need to twist harder---
bketros (06-07-2012)
Old 06-07-2012, 09:24 AM   #5
joed's Avatar
Rewards Points: 11,556
Could the pipe have been jammed so far into the valve that it is jamming it?
Old 06-07-2012, 10:11 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I do the same thing.
They also probably are turning when you're trying to turn them on due to the sharkbite connection.
Try putting a crescent wrench on the body of the valve and holding it while you turn the handle.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 06-07-2012, 03:09 PM   #7
Alright took off work early to take care of this before my wife gets home.
Turned the water off, let the pipes drain through sink in basement, put in wrench on the valve to hold it, grabbed the handle with vise grips and turned. It took a fair amount of effort but it gave way and opened. I was afraid that turning that hard would ruin it.
Now it turns back and forth easy and smooth. Thanks for the help, never new they could be so "sticky". You can believe I'll always work them back and forth a few times before installing from now on. Thanks Again!!!
The Following User Says Thank You to bketros For This Useful Post:
oh'mike (06-07-2012)
Tags
bathroom , sink , valve
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 02:17 PM
Open Stairs in Basement ngerhard Building & Construction 4 07-10-2009 07:30 PM
Which should open first GFCI or breaker jamiedolan Electrical 14 01-19-2009 04:03 PM
Boiler - Zone Valves Stuck Open djburns HVAC 3 01-13-2009 12:00 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
