Old 10-24-2009, 09:53 PM   #1
Default New Tub Shower Mixer
I just took out an old clawfoot tub that leaked and I'm putting in a new convention tub. However, There is a vertical stud directly in line with the location of the drain and new shower mixer. Should I cut the stud or just try and notch it? Its a true 2x4 so it really is 4". Would notching off 2" be a big deal? The spec sheet says that it needs to be at least 1 5/8" from the finished wall. What tool would be the best to use if notching off 2" from the stud spanning 5 feet is the answer?
jonathan03 is offline   Reply With Quote
More On This Topic
Clawfoot tubs were once the only option people had for bathtubs. Then, for a time, they represented affluence before going out of style for a half century or so. Now they're back, but many people find that repairing and updating their clawfoot tubs can... Read More »
Rod McMahon for Expert Village now when you are cutting wood it cuts very fast. You want to have it on your highest setting and you are just doing general rough demo. This one if you have a orbital setting you want that on. Here is a 2x4. You take the... Read More »
Hello! I’m Stephany of Stephany’s Simply Sewing on behalf of expertvillage.com. I’d like to show you how we stitch our sleeve into our garment. I have already pin basted my sleeve, which is this portion here, to the bodice, which is... Read More »
I'm Betty Ingham speaking on behalf of Expert Village, that we wanted to show off this beautiful old bathtub. Luckily inside the tub was good enough that we didn't have to do anything inside of the tub. We ordered this old fashioned looking shower head... Read More »
Ok. Now, we're going to talk about how we ran cold water. Again, our cold water line was already existing here. So, I cut off the old pipe added a ninety. And, we've started running it along the wall here. And, then here we have a "T" that runs up and... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
