Old 03-19-2009, 06:49 PM   #1
New tub
I have a fairly stupid question..my inlaws bought a cheapo tub (30x60 )at home depot for like 100 bucks for their condo-I am measuring the width wall to wall at 58-1/2 with 1/2" rock either side thats 59-1/2 rough opening.. so I guess my question is since its a small bathroom (58-1/2 wide and 7' long) and of course the tub sits against the back wall will this be do-able or is there tubs 59".if it is do-able does anyone have any tricks
thanks in advance
Z
zombie911 is offline   Reply With Quote
Old 03-20-2009, 09:47 AM   #2
New tub
thanks in advance
Z
No tricks , sounds like some cutting of sheet rock will have to be done with patching. Maybe someone else has a trick or two. Good Luck.
SULTINI is offline   Reply With Quote
Old 03-20-2009, 04:11 PM   #3
New tub
You must strip the wall down to the studs for tub installation.
If there was an old tub before, then you should have plenty of clearance for a new one.
porchmonkey is offline   Reply With Quote
