New Toilets - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-25-2013, 01:29 PM   #1
Rewards Points: 154
New Toilets
HI all, My son bought a house, maybe 15 years old, he needs new toilets, according to him, some don't flush well. with that said, I told him with the new water resctrictions the government has implimented now, its hard to know which toilet is good or better than than other. So I came to the PLumber Gods for answers, he found some at a box store, but one thing I know is not to buy cheap, but maybe you can find a good one there. can I get some idea on brands/models and where to buy, thanks pro's for helping us little guys out.
turbomangt is offline   Reply With Quote
Old 06-25-2013, 01:42 PM   #2
Buy a Toto Drake
davidblackwoods is offline   Reply With Quote
Old 06-25-2013, 01:55 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by turbomangt View Post
HI all,
I told him with the new water resctrictions... its hard to know which toilet is good or better than than other.
Nearly all of the early low flow toilets had issues.
Nearly all of the currently sold toilets have resolved those issues.
Some bad reputations still linger.
Old 06-25-2013, 01:58 PM   #4
Oso954's Avatar
Rewards Points: 768
I'll second the Toto Drake.
If there are no small children using it on a regular basis, go for the ADA or comfort height.
Unless mandated, I'd go with the 1.6 gpf, not the 1.28 gpf.
Oso954 is online now   Reply With Quote
Old 06-25-2013, 02:15 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
I've worked on some lousy expensive toilets
I have an 8 yr old 1.6 Sterling- not one single issue
Not sure what my other toilet is, there's no name on it
Old 06-25-2013, 03:49 PM   #6
Just make it simple, buy a Toto Drake
Don't ask about it
It's good
Will it look good in your bathroom?
Yes it will
Should you look at other brands?
No
Old 06-25-2013, 04:57 PM   #7
Why replace them? Sounds like a waste of money.... Insides always need to be replaced...
Tatertot is offline   Reply With Quote
Old 06-25-2013, 05:28 PM   #8
Oso954's Avatar
Rewards Points: 768
Why replace them?
Many of the early water saver toilets were simply anemic, as are some of the cheapo's today. They might not clear the bowl with several sheets of toilet paper in it. To clear anything more substantial took multiple flushes. You also needed a plunger close by, at all times.
Changing parts on them is a waste of money. They only cure is remove them and replace them with something better.
Old 06-25-2013, 06:19 PM   #9
All op said was is doesn't flush well.... What that means I don't know.... Some require the user to hold the handle for more water during a flush... Simply changing the type of flapper can "fix" it.
Change Wall Hung Toilets to Floor Ones ThirdBirch Plumbing 6 01-09-2013 01:12 PM
Mansfield Toilets? kcrossley2 Plumbing 9 08-23-2009 06:08 PM
Talking Toilets! ScottR Off Topic 4 08-11-2009 06:36 AM
comercial toilets Fordguy1956 Plumbing 1 01-31-2009 09:23 AM
All three toilets suddenly leaking clueless88 Plumbing 6 07-21-2008 07:07 AM
