New Toilet Or Replace Ring - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2010, 11:55 AM   #1
new toilet or replace ring
have leak under toilet
assume its the wax ring
question
is it better to just buy a new toilet than replace the ring if the toilet is about 1999 model (when house was built)
if I get new one, are the cheapo (70-90 dollar at Lowes) ones every bit as good as liek a 150-200 dollar one? is the working parts all the same?
whats the least expensive one I could get that wont be problematic?
bobmane is offline   Reply With Quote
Old 12-12-2010, 12:12 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... Replacin' the toliet for a $5.00 leaking gasket, that's gonna be replaced Anyways, don't make alota sense to Me...
Old 12-12-2010, 12:21 PM   #3
Owner
LateralConcepts's Avatar
Besides the leaky wax ring... is the one you have now problematic?
If so, what types of problems are you having?
What brand is the one you have now?
I wouldn't buy a $70 toilet.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 12-12-2010, 12:54 PM   #4
Solutions (handyman)
Rewards Points: 362
I would also find out if the water you see is actually from the seal not working or some other problem source. If you;re not sure where the leak is coming from, I would spend some money and replace the toilet as a unit. That way you have a whole new system, including a new seal, and the problem should be solved. I wouldn't go the cheapest, but mid range would do. Good luck.
Mark Harvey is offline   Reply With Quote
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 04:41 PM
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 11:02 AM
Replace tub's drain ring without removing tub? BradG Plumbing 12 03-17-2009 12:21 PM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 10:24 PM
Replace a PVC Toilet Flange bcdad Plumbing 4 12-06-2007 04:46 PM
