New Toilet Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2009, 07:42 AM   #1
Rewards Points: 154
New Toilet leaks
We had a new kohler toilet installed a few weeks ago, and I was hearing the water run every now and then, I started to monitor it, I saw the rubber plunger had a slow leak, so I called kohler, they sent me a new plunger, and its still leaks water? any idea why this is happening? Thanks, gary
turbomangt is offline   Reply With Quote
Old 09-28-2009, 09:01 AM   #2
Check the surface where the "plunger" seats. There may be a piece of trash preventing a good seal.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-28-2009, 09:08 AM   #3
Rewards Points: 154
I tried that, emptied the tank, after turning off water, the seal looks clean. the kohler rep is now sending me a different seal that goes under the tank, I guess I have to take it apart to get that on? does that make sense that this seal can be leaking, after that I'm not sure where or why the water is leaking? Gary
Challenge: Toilet Leaks through bolts but only when flushed! racerted Plumbing 53 10-21-2012 09:06 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Toilet Leaks When Flushed - How to get at closet bend!! OldHouseNewProblem Plumbing 3 12-11-2008 06:24 AM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 02:40 PM
