New Toilet Leaking At Base - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2013, 09:35 AM   #1
Rewards Points: 225
New toilet leaking at base
Installed a new toilet. The toilet does not rock. It did not leak after several usages. Tightened bolts and pushed down on toilet while installing. It is leaking now at the base. Does the toilet need to be pulled off and a new seal put on? Or can be tightened or something else? Also, the bolts came with retainer washers did not put these on. Are these for holding the bolts so it easier to put the toilet on? Thanks.
gt1935 is offline   Reply With Quote
Old 08-18-2013, 09:56 AM   #2
Rewards Points: 2,104
Feel the back of the bowl and make sure its not leaking from the tank. Feel the bottom of your tank.
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (08-19-2013), jmon (08-18-2013), plummen (08-18-2013)
Old 08-18-2013, 10:13 AM   #3
Rewards Points: 342
First, check the toilet tank and bowl for hairline cracks and manufacturer defects; rule that out as ghost suggests. Make sure you know exactly where the leak is coming from. Sometimes water can drip down the side of toilet. It may seem the base is leaking when in fact it could be coming from the tank, supply line/valve, etc.
Do not over tightened bolts, it may crack the base. Use the alternating tightening method.
Wax rings are cheap, you may have to pull and reinstall toilet base. I know it's a pain. But you have to make sure it's sealed properly. Rule that out.
Finally, those retainer washers for the base bolts, help protect the base from cracking by making sure the bolts do not contact the porcelin directly and sometimes helps secure the decrative cover/cap in place as well, depending on toilet brand. Do not tighten bolt directly on porcelein.
jmon is offline   Reply With Quote
Old 08-18-2013, 11:08 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
After you pull the toilet make sure the flange is sitting on the finished floor. If the flange is set below the floor you need to use an extra thick wax ring (or 2 wax rings).
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
jmon (08-18-2013)
Old 08-19-2013, 06:45 PM   #5
747
registered
747's Avatar
Rewards Points: 534
It might not be leaking at base. Take a good flash light laydown and take good look at tank bolts. I thought mine was leaking at base. Ended up being a tank bolt slightly dripping. Easy fix. New bolt and rubber fitting washer.
747 is offline   Reply With Quote
Toilet leaking after moving GBunny Plumbing 2 04-28-2011 04:49 PM
Water pooling around the base of the toilet mrsp48 Plumbing 5 06-05-2010 11:16 AM
Toilet leaking from seat mounting hole jrpoole59 Plumbing 11 05-05-2010 10:25 AM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
