New Toilet Install Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2008, 12:38 PM   #1
How far from the finished wall is the sewage drain supposed to be located for correct installation of a commode?
uokman is offline   Reply With Quote
Old 04-23-2008, 01:47 PM   #2
RDS
Rewards Points: 150
15"
I was just checking this myself in a DIYer book... it says minimum 15" from center of toilet drain to the finished side wall. Pros correct me if I'm wrong.
RDS is offline   Reply With Quote
Old 04-23-2008, 03:32 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Toilet will be 12" off the back finished wall, and what RDS said 15" off finished side wall.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-23-2008, 03:33 PM   #4
Plumbing Contractor
RDS is correct...as a minimum, toilets require a 30" minimum WIDTH to be installed (36" is much nicer... )
Normal ROUGH IN for a toilet from BACK finished wall to center of toilet flange is 12". This allows you to purchase a normal toilet (most options at best prices).
They also make toilets to fit a 10" rough in and a 14" rough in..but they are more expensive and there are fewer models to choose from.
Good luck...
Boston Plumber is offline   Reply With Quote
Old 04-23-2008, 03:34 PM   #5
Plumbing Contractor
Sorry Ron...posting same time you were.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 07:07 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Commerical Building - Install Drain under toilet? TransTech Plumbing 4 02-25-2008 10:08 PM
