New Toilet Flange; Not Level With Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-03-2012, 02:47 PM   #1
Rewards Points: 85
New toilet flange; not level with floor
Hi, all of my dwv pipes in my house have just been replaced with abs as a part of my bathroom remodel project.
A couple days ago I glued the flange onto the outside of the 3" pipe. I thought there would be enough play in the pipes to make the flange level on the floor once bolted down. I was wrong. This isn't even close.
What should I do? I was thinking about cutting of this flange and getting a new one that goes inside the pipe with a rubber donut and hoping there will be enough play in the donut to go in slightly crooked.
housegsx is offline   Reply With Quote
Old 04-03-2012, 02:52 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 818
If you have access below, you can cut the 3" horizontal line, then use a coupling to rotate the pipe so it's plumb.
Or call your plumber back.. if you hired the work done. No excuse for a professional.
Old 04-03-2012, 02:56 PM   #3
Just a DIY guy
He said he glued the pipe. oops
But I like your solution, better than cutting the vertical. I assume you are talking about a glued coupling, right?
M3 Pete is offline   Reply With Quote
Old 04-03-2012, 03:14 PM   #4
Rewards Points: 85
The flange is glued directly to a 90 elbow then a coupler then a Y for the shower and sink. Right behind that is my T for the vent. There aren't really any runs of piping between the fittings, everything is really tight.
The way that flange is attathed to the elbow wouldn't change if the elbow was rotated. It sits like that because it seems there is too much slope.
Old 04-03-2012, 03:26 PM   #5
Rewards Points: 85
Here is a pic from the under the floor from the closet behind the bathroom. You can see in the foreground the Y for the toilet and shower/sink. Further back you can see the coupler immediated after
the elbow, and on the other end of that coupler through the floor joist is the 90 that the flange attaches to.
Old 04-03-2012, 09:50 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
http://compare.ebay.com/like/2307326..._lwgsi=y&cbt=y
Journeyman Plumber
Old 04-03-2012, 10:02 PM   #7
Plumber
Rewards Points: 818
You have to have the riser below the flange plumb. They don't make a flange to compensate for it.
Old 04-03-2012, 10:48 PM   #8
Rewards Points: 85
Ok, so I did try to put 2 screws in on the high side. It brought it down alot so far, probably 1/2 if what is was before.
What about a little heat down the pipe? Maybe it will flex enough to make the difference.
Old 04-03-2012, 11:05 PM   #9
liscenced electrician
Rewards Points: 538
do yourself a favor and cut it all out and start the section over. It sounds like a lot of work, but it will be faster and better
jimmy21 is offline   Reply With Quote
Old 04-04-2012, 09:32 AM   #10
Doing it myself
Alan's Avatar
No. The screws that you're using to force the high side of the flange down are going to crack the plastic over time.
Both of these ideas are bad. A good idea would be to start over at the nearest fitting, and use the tool I linked to above to save yourself from having to cut ALL of that stuff out.
Journeyman Plumber
Rusted Toilet Flange and Damaged Floor in Basement Bathroom Bronxy Plumbing 5 05-30-2011 12:29 AM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
toilet floor flange joseph44 Plumbing 4 07-15-2009 04:44 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
