New Toilet; Dirty Bowl Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2011, 04:36 PM   #1
Rewards Points: 502
new toilet; dirty bowl water
I picked up a new toilet, and it has pretty impressive flush power compared to the ancient tank bolted to the wall toilet it replaced. the only problem is it sometimes leaves discolored water in the bowl after the flush.
Would increasing the water per flush help this? I'd have to extend the overflow tube (it came set from the factory tot he point were it uses surface tension to keep from overflowing), but there is extra available height in the tank. Its a 1.28 gpf model, but the base has 1.6 gpf or less molded into it, so that wouldn't be a problem.
would this solve my problem, or would I just be wasting my time. I am not too concerned about water usage. This part of the country is riddled with natural springs.
forresth is offline   Reply With Quote
water keeps leaking in toilet bowl dan ashby Plumbing 10 03-15-2011 11:15 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
No Water entering toilet bowl mjarema414 Plumbing 5 05-03-2009 01:39 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
toilet water nikotromus11 Plumbing 7 03-18-2008 07:47 PM
