Old 06-12-2007, 07:37 PM   #1
New Tile Shower trap question
I will be installing a shiower that is over a closed in area of the basement. Used to be a porch. How do I install a trap that would be accessable from the the room where the shower will be located. The shower will be all ceramic tile with a built in drain.
Would a drum trap work? Are they legal?
Is there a shower drain that can act as a trap as well?
Preciate any feed back.
Lougb
LouGB is offline   Reply With Quote
Old 06-15-2007, 03:41 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Why do you need access to the trap, nowadays the line is 2" large enough to have the line cleaned out out the trap it's self.
You really don't want to install a drum trap.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 06-24-2007, 11:34 AM   #3
Thanks for the reply. Makes sense to me.
LouGB
Old 06-24-2007, 07:25 PM   #4
remodeling pro
There should be no need to acces a modern 2 inch p trap from anywhere but through the drain itself, in the unlikely event of a clog. Absolutely do not install a drun trap, unless you like having trouble down the road. Besides, how would you acces the drum to open it up, if it is in a closed space below.
troubleseeker is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
tile shower help Atricaudatus Remodeling 13 04-01-2006 09:38 PM
