Old 06-29-2012, 03:33 AM   #1
New taps : is it me ?
Hi
I am trying to fit a new pair of bath taps. The instructions state :
"Globe taps are supplied with a threaded tube to be sealed into the tap body using a suitable thread sealant prior to connecting to pipework."
I have now fitted both taps twice using PTFE when screwing the threaded tube into the tap. First time I did 4 twists of PTFE and second time about 6 twists. Every time there has been a very slight leak from both taps.
I am starting to wonder whether a "suitable thread sealant" means something other than PTFE ? Any advice appreciated as I have never fitted a tap before !
El B
El Bandito is offline   Reply With Quote
Old 06-29-2012, 09:51 AM   #2
call me E
TheEplumber's Avatar
I would use both tape and a teflon based pipe dope such as "Rectorseal T plus 2" It doesn't matter which goes on first but most people apply tape first- 3 wraps is plenty, then apply a layer of pipe dope
Old 06-29-2012, 10:00 AM   #3
Can you post a picture?
Guessing you mean a shut off valve.
A globe valve is the last type of valve I'd ever pick as a shut off.
A ball valve would have been a far better choice.
A globe will restrict the flow and is prone to failure and leaking over time.
Old 06-29-2012, 10:30 AM   #4
Doing it myself
Alan's Avatar
Sounds like new valve stems to me. Where is the leak coming from? Around the stem, or out of the spout or showerhead?
Journeyman Plumber
Tub taps vs sink taps Mark Harvey Plumbing 0 04-24-2012 10:51 AM
Shower Taps scarrylarry Plumbing 8 04-13-2012 05:54 PM
Hissing sound in the basement taps Hoysala Plumbing 0 12-21-2009 08:17 PM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 05:52 PM
leaking taps. always something Plumbing 4 03-18-2007 01:08 PM
