-   -   New taps : is it me ? (http://www.diychatroom.com/f7/new-taps-me-148571/)
El Bandito 06-29-2012 02:33 AM
Hi
I am trying to fit a new pair of bath taps. The instructions state :
"Globe taps are supplied with a threaded tube to be sealed into the tap body using a suitable thread sealant prior to connecting to pipework."
I have now fitted both taps twice using PTFE when screwing the threaded tube into the tap. First time I did 4 twists of PTFE and second time about 6 twists. Every time there has been a very slight leak from both taps.
I am starting to wonder whether a "suitable thread sealant" means something other than PTFE ? Any advice appreciated as I have never fitted a tap before !
El B
TheEplumber 06-29-2012 08:51 AM
199 Attachment(s)
I would use both tape and a teflon based pipe dope such as "Rectorseal T plus 2" It doesn't matter which goes on first but most people apply tape first- 3 wraps is plenty, then apply a layer of pipe dope
joecaption 06-29-2012 09:00 AM
Can you post a picture?
Guessing you mean a shut off valve.
A globe valve is the last type of valve I'd ever pick as a shut off.
A ball valve would have been a far better choice.
A globe will restrict the flow and is prone to failure and leaking over time.
Alan 06-29-2012 09:30 AM
Sounds like new valve stems to me. Where is the leak coming from? Around the stem, or out of the spout or showerhead?
