Old 07-24-2008, 05:34 PM   #1
New tank new pump, no pressure??
After i got out of the shower this morning i noticed the pump had not turned itself off (above ground well pump).
So i go downstairs to see that there is no pressure building up. I try to fill the tank with air from my compressor to no avail. The system would not build pressure. So i run to my local HD and pick up the exact same tank that was there previously (Flotec 19gal). Installed the new tank after removing the old tank and flipped on the pump... Still would not build pressure! So i back to the local HD and buy a new pump (exact same pump that was existing, flotec 3/4 deep well.)
Primed the pump with water from my neighbors, close all valves and turned on the pump again.... No pressure!! I tried numerous times to prime the system to no avail. So i am here seeking help from a more qualified person. I can not imagine that my well is dry, my neighbors have no issues and the creek across the street seems to be fine. Is there anyway for a novice to perform a well check test?? Could there be something i am missing when priming?
Any help would be greatly appreciated. Oh i hope my well is not dry!!
Thank you
Kyle
Toyz is offline   Reply With Quote
Old 07-25-2008, 09:04 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
There could be a number of things wrong that would cause your system to not build pressure to cut-off.
Your pressure tank is supposed to be set at two psi below your pump cut-on pressure. If your pump has cut-on/cut-off of 30-50 psi for instance, then the pressure tank should be set at 28 psi. To test the tank pressure, turn off or unplug the pump and drain down all water pressure. Use a tire gauge to check the air pressure in the tank. Bleed it off if it is too high. Air it up with a bicycle pump or portable air tank or compressor if it's too low.
To prime a shallow well pump, you need a gallon jug of drinking water, teflon tape and a wrench. Unplug the pump.
A. Open the largest plug on top of the pump head (3/4") and wrap the plug threads with 2-3 flat wraps of teflon tape clockwise only as the threaded end faces you.
B. Fill the pump head with water, plug in the pump and quickly begin hand-tightening the plug. Air and water will bubble out as you're doing it, but that's normal. Hand tighten the plug and let the pump pick up prime, You should hear a change in pump pitch as it does.
C. If it doesn't pick up prime, repeat the process (including replacing the teflon tape) until it does. Once it does, tighten the plug with the wrench.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-26-2008, 08:38 AM   #3
Whatamess
Can you pull the well cover and look? Foot valve could have come off or cracked pipe. Check to see if you have water in the well first. Take a string with a weight on the end. Drop it in and when it hits water mark the string. Then lower til it bottoms out and thats how deep your water is. Any of these you can do.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
More On This Topic
Hi this Jon on behalf of Expert Village in this video clip I'll be showing you the parts of an air compressor. First off is the tank pressure gage that's located right here it goes directly into the tank. This is going to tell you the actual pressure... Read More »
What I will be showing you now is mounting BC to the tank. This is all done in steps, this is the first step that you will do as you prepare for you dive. Put the straps on like this, cinch it back tight so it will stay in the harness. The next step is... Read More »
Pressurizing a Lawn Sprayer
Pressurizing a Lawn Sprayer by Expert Village
We've got our pesticide in the container in the right mixture. We're going to compress the air. And that's done by pumping this handle up and down. Each time you come up it charges with air and when you push it down it puts it into the tank without... Read More »
And all of you at home, if you hear hissing once it's on, that means that you've got a problem. So, I'm on. Feels like it's leaking from--oh, it's leaking from right there. I can feel the air leaking out. So I covered it with my hand a little bit and... Read More »
Hi this is Howard Fleischmann with Community Tire here in Phoenix, Arizona on behalf of Expert Village. In this clip we'll be preparing the vehicle to empty the fuel tank and getting the tank ready to drop. We'll be changing the pump on this Yukon, and... Read More »
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 12:11 PM
pressure tank problem? steel Plumbing 14 07-03-2008 03:06 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Pressure Tank. tropic home Plumbing 2 05-05-2008 08:48 AM
captive air tank and water pressure bobcatnj Plumbing 3 04-28-2008 07:39 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
