New Stem, New Vibration - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2012, 05:59 AM   #1
new stem, new vibration
Hello-
I'm new to this forum, and I'll appreciate any help I can get. I just removed a rusted-stuck American Standard shower diverter stem, and installed an identical new one. When I turn the diverter handle from tub to shower the pipes vibrate. There is nothing to adjust on the diverter stem. It is threaded fully into place. Is there anything I'm missing? Many thanks. I'll look over all the previous threads once I have a chance, but I'm hoping to solve this ASAP.
maintman12 is offline   Reply With Quote
Old 09-15-2012, 06:08 AM   #2
Lightfoot's Avatar
Rewards Points: 272
When you got the new stem, did you make sure the screw holding the rubber washer in place was tight? Out of the package new, these are not tight and need to be tightened before installation (at least that's the way mine are). Sounds like the washer is flopping around under pressure. I know it doesn't sound like much, but it will cause the exact problem you have described.
Lightfoot is offline   Reply With Quote
Old 09-16-2012, 05:24 AM   #3
Thanks for the quick reply. Yes, that was one of the first things I re-checked. This has gotten the best of me!
Installing H&C shower diverter stem Gaca2468 Plumbing 1 06-13-2012 01:42 AM
need to replace arrow plumbing stem kjeffer Plumbing 1 08-20-2011 08:10 AM
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 12:49 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Leaky tub faucet - how to get stem out chadandjody Plumbing 4 10-24-2009 04:21 PM
