New Spigot Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2012, 01:30 PM   #1
new spigot line
I am running a new water spigot line on exterior wall about 30 ft long. I was wondering if i should use 1/2in copper or galvanized pipe. It gets about low 20s most of the winters. But it has gotten as low as 0. I live in north west az. I will be insulating with armaflex.
albert1942 is offline   Reply With Quote
Old 06-28-2012, 03:43 PM   #2
DIY staff
Rewards Points: 7,174
If PEX is allowed in your area--use that--and use a shut off with a drain--(ball valve--stop and drain)
And blow out the pipe in the winter.
PEX has the best freeze/burst resistance of any of the commonly available piping.
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 04:32 PM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 07:09 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
