#1 |
NEW sink and plumbing is slow draining, no overflow, pipes not clogged
I had an old sink that flowed fine.
I replaced the sink with a new one. I also replaced drain pipes with new standard 1-1/4" p-trap but I had to be creative to make it reach the 2" waste pipe. SEE IMAGES ATTACHED HERE. NOTE that the new drain pipe that sits in the sink itself does NOT have an overflow slit or whatever you call it, so my overflow hole in the sink never drains at all. The problem is that this new drain piping is causing the water to flow out slowly. I THINK the problem may be because of the way I did the pipe adapters to get from the 1-1/4" to 2" waste pipe???? In the photos, does it look like it would cause a slow draining. NOTE that when the sink has a pool of water, if I open and shut the drain stopper it almost always burps up bubbles and sometimes it will then suddenly drain normally/quickly. But as soon as I add more water I am back in the same situation. I'm really annoyed because the metal drain that fits the sink was the only one I could find to fit the sink and it cost something like $45 which is rediculous when you consider that it does not even allow the sink's overflow hole to flow into it. I'm really in need of some advice here.. it is disgusting to spit my toothpaste in the sink because I have to wait until it drains then hand-splash water on all the foam from the sides of the sink. |
#2 |
call me E
I don't reconize that drain assembly but thats not the problem. You need to lower the trap so it connects directly to the wall stub out. In order to do this you will need to install a 11/4" slip joint tailpiece extension between your trap and the chrome drain assembly.
#3 | |
Owner
NEW sink and plumbing is slow draining, no overflow, pipes not cloggedQuote:
Also if the ABS coming out of the wall is 2", you need to reduce it to 1 1/2 then use an 1 1/2x 1 1/4 trap adapter. Or your could just use an 1 1/2 trap and just use a 1 1/2 x 1 1/4 slip joint at the chrome tailpiece.
Brad Penske, Operations Manager - Coeur d'Alene, ID LateralCONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting (208) 818-8241 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by LateralConcepts; 07-30-2010 at 10:08 AM. |
#4 |
Thanks to both of you.
I assumed the muliple bends were obstructing the "flow" somehow... I used to work in automotive engineering and with HVAC you want the air blowing as hard as possible so you try to minimize the number of bends and especially avoid 90 or less degree bends. Of course, water and air engineering principles for "fluid dynamics" are pretty much the same... But, I originally thought the draining is not a PERFORMANCE issue, meaning you don't need FAST flow, I figured the slowest point/bottleneck is at the sink's trap itself... Now my guess is that I've caused small "burps" at the 90 degree joint, kind of like turning a jug of water upside down, where it stops up for a moment and then either burps and lets a small gush of water out, or else it just only ever allows a small flow despite the large opening of the jug. I'll let you know how it goes when I do my best to make it a straight shot to the wall stub. ..I was just tyring to optimize my storage space under the sink.. |
#5 |
I know I'm late on this post but I have to put my 2 cents in.
That drain you have in your sink is wrong, most of those are used on vessel sinks which always have a draining prob . you need to get one with the overflow holes in it and replace. Even with the pipes changed you will still have a problem.
#6 |
braindead was right.
Here's what I did to fix the issue. I used a grinding wheel on the outside side of the metal drain assembly and made a small hole at the same location where the sink's overflow drain hole is located (so it lines up correctly). I then put everything back together and everything drained quickly as a normal sink would! As for braindead saying it's the "wrong" drain, well, it's the only drain that Home Depot had that would actually fit that sink... and man it was expensive, like $45. Logically, I still don't know why the overflow drain hole needs to be present. The in-the-wall waste line has the roof pipe vent the located very close to the sink's pipe entry to the wall, and that vent is not blocked at all. |
#7 |
Try draining a bottle of water with the top submerged and see what happens, that drain assembly you have is for a vessel sink and they are known for not draining properly.
| Tags |
slow drain not clogged ![]() |
| Display Modes | |
| Need help with sink plumbing | profenx | Plumbing | 19 | 08-01-2010 05:35 PM |
| slow draining kitchen sink | Slowdrainer | Plumbing | 2 | 02-02-2010 01:56 PM |
| Help: Kitchen sink drain is clogged with grease | cips | Plumbing | 4 | 08-10-2009 11:11 AM |
| plumbing a new sink | kchiasson | Plumbing | 1 | 09-23-2008 04:04 PM |
| Need Help Plumbing A Utility Sink... | drummereef | Plumbing | 17 | 07-29-2008 04:16 PM |
