New Sillcock - Low Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2012, 05:16 PM   #1
Question
I just installed a new AMERICAN VALVE 10" purchased from Lowes. I originally had a NIBCO brand. I installed this sillcock with (2) GatorBITE Push Fit 1/2" x 1/2" Removable Coupling and aGatorBITE Push Fit 1/2" x 1/2" x 1/2" Removable Tee. After assembling I turned on the new sillcock and have a low flow of water. The other faucet connected to the "T" section has a very strong flow. I need to know what I am doing wrong. This as already took a toll on my sanity. Any suggestions are appreciated.
PyracyPyrate is offline   Reply With Quote
Old 06-14-2012, 07:13 PM   #2
Is everything the same diameter after the T? Water will obviously take the path of least resistance..
TSGR is offline   Reply With Quote
Old 06-14-2012, 08:21 PM   #3
I have the "T" then about 1 1/2" to 2" pipe and then a GatorBITE Push Fit 1/2" Removable Female Adapter which is attached to the sillcock. It is threaded with Teflon tape. I am not to sure if it is the sillcock, or the connections. Here is a picture of the connections
Tags
american valve , outside faucet , plumbing , sillcock
I thought I understood plumbing, private well flow rate question ChrisDIY Plumbing 22 07-25-2011 10:14 AM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 05:05 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
Flow not Pressure problem??? DonM Plumbing 5 11-29-2007 05:53 PM
