Old 09-12-2012, 09:19 AM   #1
REDRUM's Avatar
New Shower (Plumbing valve question)
i am removing a tub and installing a 4'X7' shower all built from scratch, i have not built the walls or bought the valves yet... i had a thought while at home depot....
can i purchase a shower and tub valve w/controls and plumb the tub feed to another shower head ? i realize that i will only have one or the other but thats not a problem i am going to do this on both sides of the shower.
my question is will it work ?
REDRUM is offline   Reply With Quote
Old 09-12-2012, 09:59 AM   #2
Can't answer your question, but do you realize you will need a 2" drain for the shower?? Tubs only have a 1-1/2" drain.
Old 09-12-2012, 10:04 AM   #3
Why not just splice the water lines with a T and add your aditional shower head to the other side with matching control valves??
pwgsx is offline   Reply With Quote
Old 09-12-2012, 11:18 AM   #4
REDRUM's Avatar
got that covered, thanks
Old 09-12-2012, 11:19 AM   #5
REDRUM's Avatar
i could, but that leads to more controls, plumbing, etc. the tub shower and shower only valves are no diff in cost.
Old 09-12-2012, 09:44 PM   #6
I did the exact thing for one of my bathrooms and it works great.
Few comments about this setup:
0. you need a 3 control setup (hot, cold, diverter)
1. Long levers will interfere with each other. Get a short handle lever or even better a round one;
2. Depending on the brand, you can have both showerheads operate at the same time and it is awesome!
3. If the space above your bathroom is an attic, make sure to insulate your pipe
The only minor draw back is that if you use the rainshower head, you need to put the diverter in the middle position to allow the pipe overhead to drain (or else, it will dump water in the middle of the night when you lease expect it)
allthumbsdiy is offline   Reply With Quote
Old 09-13-2012, 08:58 AM   #7
REDRUM's Avatar
You the man
thanks
Old 10-16-2012, 12:43 PM   #8
REDRUM's Avatar
Originally Posted by allthumbsdiy View Post
awesome, works great, have not had the "dumping water yet"
thanks again
Old 10-16-2012, 12:48 PM   #9
REDRUM's Avatar
Old 10-16-2012, 12:54 PM   #10
REDRUM's Avatar
Shower Valve Question dmpjr Plumbing 5 04-22-2012 08:37 PM
Shower plumbing questions from a novice slkarns Plumbing 7 04-11-2012 10:28 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 06:45 PM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 10:06 AM
Shower valve question tmbrink Plumbing 3 12-03-2008 12:40 PM
