Old 08-05-2009, 06:42 PM   #1
New Shower Gooseneck issues
Okay, we just remodeled our master bath and the glass was just installed on the shower so I am wanting to use the shower! I go to hook up the shower head and I am having trouble screwing the gooseneck pipe into the brass fitting. I am using teflon tape. At first the pipe was sticking after only one and a half rotations, now I can get it about five rotations before it gets really hard to turn. Is there anything I can do? would dope work better? The threads feel kinda rough. The first time I got it twisted in about 5 turns total and turned on the water and it was pouring out, so I need to get it around at least 3 more times for a proper seal. Help! Is there something that could be used to clean the threads?
banightingale is offline   Reply With Quote
Old 08-05-2009, 06:53 PM   #2
biggles's Avatar
get a nipple the same size as the gooseneck pipe and hand thread it in raw no teflon then put a channel locks on it to clear the grooves..you should go in hand tight then one full turn with a wrench on the gooseneck for final install
Old 08-20-2009, 11:59 AM   #3
Worked like a charm and we are enjoying our new shower!
leaking shower gooseneck gator0625 Plumbing 4 06-16-2009 10:06 AM
water pressure in shower issues sflamedic Plumbing 8 04-07-2009 02:55 PM
shower issues kro General Discussion 5 01-27-2009 07:12 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 11:52 PM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
