New Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-05-2013, 04:42 PM   #16
DIY staff
Rewards Points: 7,174
1/2" will be fine---when you pack the deck mud for the preslope ,fill in under the drain flange.---this will give you a stable footing for the drain.
ScottFla40 (07-05-2013)
Old 07-05-2013, 04:51 PM   #17
ScottFla40's Avatar
Mike, your a gentleman and a scholar. I dont want anyone to think I don't appreciate everyone's advice because I do.. I look to this forum often for advice and I always can count on everyone. Thanks again..
ScottFla40 is offline   Reply With Quote
Old 07-05-2013, 06:40 PM   #18
DIY staff
I've built a bunch of those----sometime you have to do what works---
Old 07-07-2013, 05:16 PM   #19
Master Plumber
Javiles's Avatar
Rewards Points: 994
Originally Posted by ScottFla40 View Post
Mike,
I appreciate the link. I guess I am just looking for the answer if 1/2" is low enough above the slab.
I am not planning on chipping out and replacing the cast with pvc. As far as I am concerned that is asking for trouble especially being that I do not have a basement to go in and look where the cast ends. I feel that that the direction I am headed & the work I have done is ok to this point.
So is anyone willing to answer my original question of is 1/2" ok??
Asking for for trouble is leaving that cast trap in the ground, trouble is a clogged shower down the road and a cable going through the weakest part of the drain after ex amount of years of use, the base of the trap, guess what needs to get done now.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is online now   Reply With Quote
Old 07-07-2013, 05:54 PM   #20
ScottFla40's Avatar
Jav,
I see your in Miami. I am in Pines. Care to come out & give me an estimate??..
Old 07-07-2013, 06:07 PM   #21
DIY staff
You will not be sorry if you replace it----leaving old parts under a new pan is not a good idea.
Old 07-23-2013, 07:09 PM   #22
ScottFla40's Avatar
Well... Did the preslope, and put the liner in but I am concerned about how I cut the liner a bit wide around the drain. I put the silicone under the liner and bolted the flange down. Should I be concerned??.. Would appreciate opinions.. Thanks guys..
Old 07-23-2013, 08:18 PM   #23
Rewards Points: 1,866
Who did you attach the PVC part to the cast iron part?
Old 07-23-2013, 08:30 PM   #24
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,464
Considering you are on slab..... yes 1/2 inch should be ok for the pre-slope slab at the drain.... I like 3/4+.... but you are on slab and I think you'll be fine.
Just my opinion.
EDIT:Sorry did not notice this had a second page to the thread and the question had been answered.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-23-2013, 08:37 PM   #25
I believe your hold down plate is going to cover that hole and make a seal...... try putting it on
Old 07-24-2013, 06:40 AM   #26
ScottFla40's Avatar
Fernco
Old 07-24-2013, 06:38 PM   #27
Figures.
Old 07-24-2013, 06:44 PM   #28
ScottFla40's Avatar
Figures.
Why's this???...
Old 07-24-2013, 09:45 PM   #29
A fernco is like a radiator hose. It also is not the approved way to connect from cast iron to pvc pipe. A transition coupling made for your connection from cast to pvc would have been the right way to do the job.
Also make sure you block the drain and water test up to the top of your shower threshold. Let it sit for a few hours. There should be no leaks or wet wood around the shower if your liner was done right. Make sure you read the liners install instructions a few times over and over. No nails within 1 inch of the top of your threshold. No nail through the top of your threshold the liner should wrap the threshold and be nailed on the outside front.
If you nail the liner on the top of the threshold water will leak into the wood and it will rot. In about 6 years you will get to do it over again.. It was a common error I noticed when we had to inspect liners. Water runs down your door through the grout and down the nails. Water will find a way out if you give it a way.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Drain pipe size for roll in shower frickell Plumbing 1 04-05-2012 08:36 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
