New Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2013, 07:26 PM   #1
ScottFla40's Avatar
New Shower Drain
Installing a new shower/master bath remodel. I had to install a Fernco to the cast iron drain pipe then to the pvc nipple & drain. My concern is that the new drain will be too high. The top of the drain is 2" above the slab, my framing for my curb is 3" high. Will the 2" height be ok?..
New Shower Drain-image-791705571.jpg   New Shower Drain-image-1644529828.jpg   New Shower Drain-image-924552076.jpg
ScottFla40 is offline   Reply With Quote
Old 07-04-2013, 08:24 PM   #2
Rewards Points: 12
It's not going to work unless you plan on making your pan plus the tile 2" thick. Plus your curb inside the shower will be about 1" tall.
Dan
djlandkpl is online now   Reply With Quote
Old 07-04-2013, 08:43 PM   #3
ScottFla40's Avatar
Suggestions??...
Old 07-04-2013, 08:50 PM   #4
Rewards Points: 12
Can you describe what is below the slab or post some clear photos?
Is the Fernco connected to the trap or a straight run of pipe? You need to get the drain height lower. It might involve breaking out the concrete to get at more of the pipe.
Dan
Old 07-04-2013, 09:00 PM   #5
ScottFla40's Avatar
I am in Florida. Under the slab is grade. I already chipped out the concrete and took 2" off the cast iron pipe. Its a vertical pipe coming from under the slab. A little background for you. The original 3 piece pvc drain was just set on the cast iron drain pipe, no okum, nothing. Just lifted right out when I chipped out all the old mortar bed. The pic is before I chipped out the concrete & cut the drain down 2"...
Old 07-04-2013, 09:05 PM   #6
Rewards Points: 12
You need to cut more off the cast iron so you can get the drain to the finished height of your floor.
Hopefully one of the pro plumbers will stop by and give more ideas.
Dan
The Following User Says Thank You to djlandkpl For This Useful Post:
ScottFla40 (07-04-2013)
Old 07-04-2013, 09:10 PM   #7
ScottFla40's Avatar
I mean if I have to cut more pipe I am going to have to chip out almost all the way to grade... Eeeek!!!!...
Old 07-04-2013, 09:30 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 452
Why is the drain body so tall? Can't you find a lower profile?
Old 07-04-2013, 09:38 PM   #9
ScottFla40's Avatar
The original pvc drain was literally just set on top of the cast iron drain pipe. I wanted to add a Fernco, 2"x 2", then a 1" nipple of 2" pvc into the bottom of the new drain & into the Fernco.
Old 07-04-2013, 09:41 PM   #10
Plumber
Rewards Points: 452
You should use a 2" drain body only- it will attach directly to the pipe- no nipple needed.
That drain looks like a 3" with a bushing in it
Old 07-04-2013, 09:46 PM   #11
ScottFla40's Avatar
Its 2". So the 2" drain body would just rest on top of the pipe?. No Fernco needed?. That's how the original drain was, just set on top of the pipe...
Old 07-04-2013, 10:18 PM   #12
Plumber
Rewards Points: 452
There are multiple drain bodies available. Looks like yours has a hub on it and you glued a pipe stub into it. this makes your drain a couple inches taller.
you want a body without the hub- the outlet is the same diameter as the pipe.
You then connect the body directly to the pipe in the ground using a no-hub coupling- it's the same as the fernco except it has an exterior shield to it. Much better than a normal fernco
The Following User Says Thank You to TheEplumber For This Useful Post:
ScottFla40 (07-05-2013)
Old 07-05-2013, 04:40 PM   #13
ScottFla40's Avatar
So here is the hopefully finished product. Took off more of the cast pipe. I have a 1/2" between slab & drain.
New Shower Drain-image-13785937.jpg   New Shower Drain-image-3738521479.jpg   New Shower Drain-image-2744861403.jpg
Old 07-05-2013, 04:55 PM   #14
DIY staff
Rewards Points: 7,174
E-Plumber--that is a membrane clamp drain for 2" PVC---
Scot---You will not want to hear this, but I'll bet you already have it figured out---
Open the concrete---cut out the old P-trap and change it to PVC---then everything will work right and you will eliminate the rusty old trap from your life.
Rent a large chipping hammer or a jack hammer and be on the way---
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Old 07-05-2013, 05:29 PM   #15
ScottFla40's Avatar
Mike,
I appreciate the link. I guess I am just looking for the answer if 1/2" is low enough above the slab.
I am not planning on chipping out and replacing the cast with pvc. As far as I am concerned that is asking for trouble especially being that I do not have a basement to go in and look where the cast ends. I feel that that the direction I am headed & the work I have done is ok to this point.
So is anyone willing to answer my original question of is 1/2" ok??
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Drain pipe size for roll in shower frickell Plumbing 1 04-05-2012 09:36 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 12:59 PM
