New Radiant Zone To Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2011, 11:07 AM   #1
new radiant zone to boiler
Gm to all
I have a boiler with 4 baseboard zones and want to a radiant zone
IS it necessary to have a circulator on a designated radiant zone
HANDYDAVE1 is offline   Reply With Quote
Old 05-10-2011, 01:37 PM   #2
Just call me Andrew
Rewards Points: 1,020
When you say radiant do you mean in-floor heating?
How is your current system set up? Do you have one circulator pump and zone valves or does each zone have its own circulator?
Andrew
secutanudu is offline   Reply With Quote
Old 05-10-2011, 02:37 PM   #3
Hi Andrew
Thanks for your effort
The radiant zone will be a new zone in floor
I know have 4 hight temp zones with a circulator for those zones. each zone has its own zone valve
Old 05-10-2011, 04:41 PM   #4
Just call me Andrew
A moderator should move this thread to the HVAC section.
One of the HVAC experts should better be equipped to answer this, but assuming the pump can handle the additional load, I'd think all you need is another zone valve. You also need a mixing valve to reduce the temperature of the new radiant floor zone.
Andrew
Old 05-10-2011, 10:13 PM   #5
Andrew
I have reposted this ti the hvac section thanks
Super Hot Boiler - zone problem jromero816 HVAC 5 12-28-2010 12:59 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 07:28 PM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-13-2010 12:17 AM
Boiler heating zone not working properly ssevern HVAC 5 12-19-2009 07:05 PM
