| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Mount the Regulator to Tank: Scuba Gear Basics
by Expert Village
What I will be showing you now is mounting BC to the tank. This is all done in steps, this is the first step that you will do as you prepare for you dive. Put the straps on like this, cinch it back tight so it will stay in the harness. The next step is... Read More »
How to Check Tire Pressure on Trailers
by Expert Village
Hi, I'm Albert Hedgepeth with Expert Village. Today we're going to talk a little bit about trailer maintenance. Let's talk a little bit about tires and tire maintenance on a trailer. One of the really major things you need to look at is since tires are... Read More »
Motorcycle Power for Stoppie
by Expert Village
Hi, my name is T.J. I'm here with Expert Village. And, we're here today to talk about how to do stoppies. Alright, now we're going to talk about tire pressure. When you're doing stoppies, it's easier to do stoppies with lower air pressure in the front... Read More »
How to Best Utilize Air Tanks While Paintballing
by Expert Village
Hello my name is Orestes Guada for Expert Village. Today we are going to talk about paintball equipment. This is a tank that I use on my gun. It is a low pressure, cause my gun only uses low pressure. Is is a 6845, holds 45 PSI. It is a limited edition... Read More »
The Parts of an Air Compressor
by Expert Village
Hi this Jon on behalf of Expert Village in this video clip I'll be showing you the parts of an air compressor. First off is the tank pressure gage that's located right here it goes directly into the tank. This is going to tell you the actual pressure... Read More »
