New Plumbing..Old House - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2011, 07:05 PM   #1
Rewards Points: 29
New plumbing..Old House
Hi all, I am planning on doing a bathroom renovation and I have to redo the plumbing because it all runs in same line as sump pump water backs up into bathroom sink big pain. I will be adding shower/tub another sink and want to redo pipes from kitchen and sump so I can run seperate lines. This picture is what I have now for an outlet I would like to change to pvc with multiple outlets. Plumbing 123 I know I just dont know wheres a good place to convert the cast iron to plastic. I have seen the connections to do it I just dont know if I should do it on the flat run or on the vertical run?
Thanks Shawn
Shawnzy is offline   Reply With Quote
Old 12-05-2011, 07:17 PM   #2
Rewards Points: 582
you are taking on a good size project....I would connect on the verticial as low as possible maybe just 3-4 inches above 90 exiting house....keep in mind the adding fixtures and vents....very important....permits & inpsections?
Old 12-06-2011, 11:18 AM   #3
Rewards Points: 29
I know I am it can be done, and I ask local building office if I need one for every project.
Old 12-06-2011, 05:37 PM   #4
Rewards Points: 582
yes it can be done and you will have alot of help....ben
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Help please! New house plumbing question Cdessel Plumbing 1 12-02-2011 11:28 PM
Shoring and Video plumbing inspection. Is it worth it? Geaux4Tigers Plumbing 22 12-12-2010 02:48 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
